I have a 2013 Honda BF150. The motor will crank and run good, but when the motor is shutdown for about 15 minutes will not re-crank (starter turns engine, but motor will not crank). After the motor sets for about an hour the motor will crank. I have changed both fuel filters and cleaned the fuel separators. I duplicated the problem at home and checked for fire at the plugs - Had fire. I used a little starting fluid and the motor did momentally cranked - Telling me its a fuel issue. Acts like a vapor lock, but the motor isn't running hot. Reading other threats, I'm thinking maybe the starting relay to the high pressure fuel pump.
Your thoughts and advise would be greatly appreciated.
Dale C.
Dale C.
