Honda BF15 water draining question
hammerdog
"I bought a Honda 15HP motor i
"I bought a Honda 15HP motor in as is condition. The first time I took it out on water, it overheated and I found no water coming from pee hole.
I checked and found the impeller fins broken. I installed new impeller/pump housing/gaskets.
Today, I started it in the driveway using the garden hose/marine clamp attachment. The motor started and ran fine, water was coming out of the pee hole.
I also saw water draining from (2) of (3) holes in the cavity where the engine exhausts. I took the engine cover off and found water had filled up in this cavity and was continuing to drain from the (2) holes as well as the pee hole.
I am new to Honda. Is this normal for a BF15 or do I have another problem."
That's normal. After the w
That's normal. After the water cools the powerhead it goes down the exhaust housing. The theory is that it will form a "wall of water" to act as a muffler. Helps cool the exhaust and keep the noise down...
