Honda BF15 that will not run WOT
handinpalm
I had problems with my BF15 running at anything above high idle. I thought it was a dirty carb, so replaced with brand new Honda carb. Motor runs good at idle and will rev to high RPM sitting in driveway with no load. When I go out for sea trials the motor will not run above a high idle, even though I have it at WOT. It also seems to run a little rough at idle and is a little slow to rev high with out load. The motor had the fuel bowl replaced in recall last year. I took off fuel filter and it is not clogged. I pumped primer ball while running WOT, but no help. Do brand new carbs need the jets set? Anyone have any suggestions? Thanks in advance.
Mike
