"Hey guys
My engine overheate
"Hey guys
My engine overheated last fall. I replaced the impeller, housing, tube seal and thermostat. It worked great. This week I took it back out to test it before putting it back on the boat. The tell tale was not ejecting water (slight steam). I blew out all the passages with compressed air. I disassembled the pump again to check it out. The impeller looked good, the new housing was not scored. I reinstalled and tested again. No water came up to the thermostat outlet or out the tell tale.
After being very frustrated I reluctantly disassembled the lower unit to check the impeller again. I never tested the impeller to see if it was tight to the shaft. Low and behold it was spinning free on the shaft. I pulled the impeller off to discover the steel key was buried into the impeller to the point it had busted through the plastic inner sleeve.
I think the impeller was defective. Any thoughts? It's a Sierra part made in Taiwan. I noticed the keyway on the old impeller lines up with one of the rubber blades but not on this Sierra part. Should I be looking for Honda OEM parts? I bought a 18-3280 kit which replaces Honda 06192-zv4-000. Is this the wrong part #? Also it seems the little half moon key could be a bit longer?"
My engine overheate
"Hey guys
