flying fisherman
I have a 1999 Honda BF130AXXA model that dies when shifting from idle to forward. This occurs after the motor has been run at extended idle time and also after extended trolling speed and attempting to give more throttle. I have had the following parts replaced by several mechanics including several certified Honda mechanics. New fuel injectors, throttle body assembly and associated oxygen sensors and a new idle control motor. None of these things have fixed the problem. It still stalls when shifting to forward after extended idle It doesn't happen every-time and it always restarts immediately with key. The new concensis is to replace the ECM, electronic control module to the tune of $480 plus shop time. Are there any other suggestions before I go this route? I've invested about $1800 in Honda parts and associated labor fees and haven't fixed the original problem. The first Honda dealer that replaced the injectors was already in bankruptcy proceedings unbeknownst to me at the time of the injector replacement and i had no recourse for further work there. Thanks for any suggestions. I don't know if there is a common malady associated with these motors that I should pursue.
