Honda Bf130 spark plug wires
c-level
I need two new spark plug wires (just the wires not the ignition coil) and was curious if the wires were specific for each cylinder? I know that the ignition coil set is labeled 1,4 or 2,3 but from what I could tell when I looked at where it was attached to the ignition coil they had screw ends. Would it be possible to get different wires and swap the locations, i.e say I need a wire for number 3,4 could I use a wire from #1 or #2?
There is no difference in the wires except maybe length. The are numbered so you put them on the correct spark plugs.
Mike
That's what I was hoping to hear mike, thanks! By chance those wires aren't the same as a regular 2002 civic spark plug wires are they?
Mike the ends of the spark plug wires have a screw attachment that goes to the ignition coils. Do you happen to know if they are made to just unscrew and you can swap the wires out without swapping the coil? I've looked as schematics and they all show it as one piece when you buy it but I can't believe honda would make those unscrewable without having a reason.
