DOCK DOG FRED
Good evening, i ran across this web site and found the answer
to my starting problem that i had been pulling my hair out on.
Thanks so much.
I bought a pontoon boat the first part of the year, it ran in fresh water at sea level. I am running this boat at 5500'-6500'
in the mountain lakes. I have only had a chance to use the boat a few times so far, the snow just melted up high not long ago.
I have installed new plugs, drained carbs, drained fuel tank
installed new fuel, adjusted the valves, complete service, even installed two new fuel pumps and filter. Every thing checks out fine.
The motor starts out running great and keeps running fine.
But if you turn it off and it sits for 15-20 minutes and then you start it back up, the motor will run rough and not run up above about 1200 rpm. Then you have to play with the throttle, sometimes it dies, or just chugs along for a bit. If you can keep it running for 5 minutes or so, it will start to clear itself out and then run fine. I know i may need to reset for high altitude, also i can only get about 4200 rpm out of the motor under full load.
Will run up to 6000 rpm out of the water. I am sure i need a new prop with less pitch, could sure use some advise. Thanks so much.
Thanks so much.
