Hi, I have been getting some great info from this forum and it was past time for me to join. I am having a really hard time dropping the bottom unit on my 2002 honda 90 and would really appreciate some help. I have the seloc manual, which provides a bit of info but not everything. I have loosened the 4 bolts from both sides of the lower unit, and removed one bolt from just forward of the skag. I allso removed the skag/trim tab and found nothing under it. The manual suggests that there could be a bolt hidden under a iregualar cover, nothing like that on my motor unless there was a cover for the bolt forward of the skag. It says the shif linkage is splined, and when i try to remove the lower unit it still shifts freely with force applied.
So, the after end will seperate easily enough to about 1/8-1/4", and i have used a mallet and a block of wood to tap around the forward (gear shift end) with no luck.
I sprayed it penetrating oil and left it overnight, still no luck. I put a small wedge in the afterend and spread it to about 1/4", and then used screwdrivers on the sides to apply more pressure.. then tapped again.
No luck, and so far no real damage to faces on the upper housing and bottom unit.
Anyone have any ideas?
