"I just bought an older sailbo
"I just bought an older sailboat which came with a 1979 BF75 7.5 p motor. The motor spits a little water when at idle, and the stream increases at higher rpm, but the water get very hot, so I am assuming it needs a water pump.
I started to remove the lower end to look at the pump assembly so I can order the right pump but I can't seem to remove it completely, feels like the gear shift shaft must be discconnected somehow. Any trick to this? Do I need to open the pump housing get the seperate the bottom end?I am ordering a manual, but would like to get a head start on getting the impeller order."
