It is a Honda tool...07MAB-PY3010A 50 mm offset and 07JAB-001020A Handle. NOT CHEAP! The bolt takes a 19mm socket. Someone else on the forum, may have another way of doing it. I have used the flywheel lock (which locks the crankshaft) and one time and it worked, but it was still a bear.
You might be able to change the seal without removing the cover with some ingenuity. I have never tried. I normally have the cover off for other things and changing the seal is easy then.
One hint....The crankshaft pulley has a key in it... It normally is not a tight fit, so if you are not careful and grab it as you are taking off the pulley, it will fall into the hole and into the timing chain cavity. Then you will have to take off the cover. When you put the pulley back on, put the pulley on first and then slip the key in the groove. That way it should not fall into the hole.
Mike
