Honda 50HP 2006 Impeller replacement
pebaugh
Can anyone send me the instructions on how to replace the impeller on my 50HP 4 stroke Honda 2006? I started it today and luckily I noticed within one minute that water was not recirculating and exiting the engine. The motor has had 4 moderate use seasons and I understand that the impeller should be replaced every 2 years.
Is there also a kit with gaskets, impeller etc I can buy along with the instructions?
There should be 5 bolts holding the lower unit, don't forget the one under the cavitation plate. you also have to disconnect the shift shaft . the lower unit should drop although it may need a bit of persuasion with a rubber mallet.
Don't think you will find instructions aside from the shop manual.
Take your engine serial # with you when you go for the parts, the impellor itself
cost me $45 !!
