Hi all Just found your site while looking online for help with a outboard problem I'm having, looks like a great forum!
I have a pair of 2011 honda 50EFI's , had Hondas all my life and never had any major problems, my 4th set on this boat
My engines hadn't been run for 2 weeks due to bad weather until today ,I went to go out , one engine started fine as usual, other engine I notice there was a very slight delay ( probably just a second) after turning the key to starter kicking in, I thought at the time that's odd but engine started fine and was running ok, I moved boat in harbour to take some gear aboard and switched both engines off. When I went to go out again 10 mins later ,the one that had the slight delay starting previously was completely dead, turning the key the ignition would bleep but nothing happened.
I went through everything I could think of to check - battery cables/leads, battery's, looms all seem fine, all control box wiring appears fine, fuses all ok, all connections on engine seem fine, tried tapping starter gently with a hammer in case it was stuck, the start in gear protection switch was my initial thought as I have had problems with these on previous engines with the metal flap bending but it all seems ok.
I was planning on swapping the starter with the other engine tomorrow to rule that out first, is there anyway I could bypass the start in gear protection switch to rule that out too?
Any other ideas or help would be much appreciated, thanks
