My 50 honda will not do anything. will not run crank or even click click. I suspect the ignition switch itself. When the key is turned on even the tilt trim indicator will not even come off the peg to "neutral". Even wonder if maybe battery cable kaput. Will kill switch ground out everything Start where?
battery is good. If I jumper straight to starter motor it runs starter
