Honda 225 won't start no lights at ignition and was working fine until I disconnected everything to clean and tighten connections. Been having some electrical problems. Replaced some corroded fuses on the Lenco Trim tabs and Seastar Power assist which were oddly enough tied into the ignition switch. Anyway, my starboard motor kept blowing #3 10amp fuse. Replaced all mentioned fuses and holders listed above. Now starboard motor runs fine and port motor won't start. First, all the four lights were going off with a constant alarm. So I disconnected everything and clean connections and now I get nothing from the key switch. I do hear a clicking noise out of the lower black box relay when I try to trim the motor. The main ground wire is clean and tight. I am stumped. Thanks for any help.
