Honda 225 propeller
J
J. Jones
Guest
"Hi There
I recently bought a
"Hi There
I recently bought a new Honda 225, however i can only reach 38knots at a max of 4200 rpm. We currently have a honda ss propeller 3x14 at a pitch of 22 inch, can anyone reccommend a propeller which will give me the desired full 5800-6000 rpm??
Thanks"
"Prop is too large. What is s
"Prop is too large. What is size and weight of your boat. Likely you will have to go to a 19 pitch or 17 pitch. Also have to consider height of engine, aluminum/ss, 3 blade/4 blade, and cupping or no cupping. I am running a 15 14 X 17 3 blade SS prop and lightly loaded can hit 6200 RPM's."
contact the Honda dealer that
contact the Honda dealer that installed the motor and they should help with different props till you find one in your operating range. With it being that new unless it is scratched up or dinged more than likely will be an even trade or close to it depending on the different prop that you settle on.
Another source would be contacting a dealer that sells the boat and asking if they have any experience with that hull/motor combo.
