Honda 2004 BF150 Shift Rod stuck
Tyone
I pulled lower unit and when I went to install the lower unit the shift rod will not shift out of neutral into forward gear (this still occurs when the lower unit is not connected), however it will shift into reverse. Is it possible that shift shaft A and B are misaligned...if so how do you re-align.
First of all, can you shift the lower unit? Are you turning the prop shaft when you try to shift?
Sorry for the basic questions...
The lower unit should be in neutral the the flat spot on the shift shaft faces forward.
Did the long shift shaft going up the motor get removed? If so, was everything from the helm in neutral at the time?
If you had a difficult time putting the long shift shaft in and pushed or tapped on it too hard, you could have knocked off the e ring that holds shift shaft A.
If you did this, it is very difficult to put back correctly without removing the powerhead.
It is possible. You need great patience, long needle nose pliers, a small mirror, and lots of luck. We will address that when you are sure they are out of alignment.
The check for sure.
Make sure your shifter is in neutral. To check to see if the engine also thinks you are in neutral, turn the key momentarily to start the engine. If the engine cranks, the engine thinks you are in neutral. If not something is wrong from your shifter to the engine shift shaft B.
If it is in neutral, and the long shift shaft is in....is the flat spot in the shift shaft facing forward? If it is not, does it move up and down if you push on it? Watch the bottom of shift shaft A where it connects to the long shift rod. You should be able to see the junction just above the vertical swivel of the engine just below the engine lower casing.
If it is going up and down more than a little bit, the e ring has been knocked off.
I know that was a lot of questions. Hopefully, it is not this complex.
Just remember, whenever you are trying to shift the gear case when the motor is not running to turn the prop shaft. Sometimes the clutchdog gets hung up on part of the gear that you are shifting into.
Mike
:)First thanks so much to getting back to me. I'll answer your questions in the order they were asked.
1) yes I can shift the lower unit. The lower unit is currently off of the outboard and shifts very easily into reverse, neutral, and forward.
2) The long shaft did not get removed. Prior to re-attaching the lower unit I did make sure the lower unit and the shifter were in neutral.
3) The lower unit is still off the outboard and the engine will not start unless I push the switch assembly (neutal) button in.
4) The shift rod does move up and down so.........I'm afraid I did knock off the e-ring.
So I believe my only option now is to remove the powerhead...do you concur or please talk me through how to get things realigned using the great patience method and long nose needle pliers.
Again thanks for taking the time to respond. I'm hoping to get this motor back running by the 1st so that we can head up to the cabin for 10 days. Our summers are short up here, so we cherish the short time we have to play on soft water.
This will be brief since I am working today...
I am not sure what you mean by pushing the neutral button.
If the shifter is in neutral, just turn the key to see if the motor cranks. Do not start it.
If you have to do something else, the shift detent is not depressing the neutral safety switch on the motor.
One other thing. Double check for the e ring to see if it is there still in place or if it just got pushed down. In any case, if you did dislodge it, you have to find it or get another one.
I have done this to a 130 or 150 - I can not recall which. They are basically the same where the shift shaft connects.
If you have to pull the powerhead, you should get a Helm manual. It is not as easy as it may appear. Hopefully, you will not have to do this.
Let me know what you find.
One other thing. Check the end of the long shift shaft and see which direction the flat spot is.
Continue later...
Mike
Thanks Mike...when I said, ..."I push the switch assembly (neutral) button in" I was referring to what you described "the shift detent is not depressing the neutral safety switch". I have the lower unit off of the outboard and still cannot shift the motor. I have disconnected the shift and throttle cables to make sure the problem was not the shift/throttle helm. I cannot shift the outboard manually so I'm still thinking that the e-ring which holds shaft A is dislodged...not sure. The direction of the flat spot; the flat spot is off to the right about in the 2:00 o'clock position. You recommended the helm manual...will order next.
Thanks again
Pete
The shift detent or the arm which pushes in the neutral saftey switch is up against the switch but not pushing the button in. Since we have talked last, I have removed the shift link bracket and pulling on the shift arm which is attached to shift shaft B still does not allow me to shift the motor.
Pete
Ok, try this. The following is assuming that you did not remove the long shift shaft and it is properly installed into the shift shaft under the power head.
Make sure that the shift shaft on top, is aligned correctly to depress the neutral safety switch. The fact that it does not depress it is a concern, but you have to get all the alignment straight first.
Check out parts 12 and 18. http://www.boats.net/parts/search/Honda/Outboard%20Engine/2004/BF150A4%20LA%20MARINE%20ENGINE%2C%20JPN%2C%20VIN%23%20BANJ-1000001%20TO%20BANJ-1099999/SHIFT%20SHAFT/parts.html
18 is the part that you would have just adjusted to align with the neutral safety switch.
12 is the part that is evidently out of alignment. Be sure that you can see where the long shaft goes into it. 12 and 18 are probably about 1/8 inches thick. As you can see, you probably have one of these (#12) all the way to one side.
Stick a needle nose plyers in the end of the long shaft with the flat part of the needle nose on the flat part of the shift shaft. That way you can see which direction the flat spot is without bending way over and you will have better control when you try to turn the shift shaft. You may want to have someone else with steady hands help you.
What you are going to do now is push the long shift shaft up just 1/8 inches...maybe a little more. This should make #12's teeth raise above $18's teeth. Be sure to watch under the engine so you do not push it in too far. You may need to grab it later with a needle nose to pull it back down. Just remember...the long shift shaft could come out at any time...and it will probably be the worst time.
While you are making sure the top shift shaft #18 is not moving, try to turn the long shift shaft (while still pushing it up 1/8 inch or so) until the flat spot is forward.
Gentle pull the long shift shaft back down, wiggling it back and forth a little so that the teeth of the two shift shafts link up. You may need to help pull it down where the long shaft connects to #12 with needle nose.
At this point you can very carefully move the upper shift shaft and see if it rotates both ways.
If you were successful...now the hard part. You have to put the e clip (#11) into position to hold the #12 in place. A long needle nose should be able to do it. As I said in a previous post, if this is indeed the problem, the e ring may still be on the shaft of the shift shaft but just pushed down the shaft. If so, you will have to pull it off and install it in the little grove on the shaft of #12.
Do everything is small increments so you do not loose the #12 into the bottom casing. Once you do, it is powerhead time.
I do hope we are going down the right path.
Mike
Good evening Mike,
Had a very wet storm move through yesterday so I really didn't get serious until tonight after work. Just like you said earlier, with some luck and great patience the steps you outlined may work. Well I'm happy to say success was achieved. I'm so glad that I did not have to go the route of removing the powerhead. I'm very grateful for your help and advice. Thanks.
Pete
