Honda 135 2006 conks out after 5 minutes
Squeeze the fuel bulb and see if it keeps running.
If so, then you have a fuel delivery issue. Could just be a bad bulb (bulb arrow should be oriented up or at least horizontal...not down.)
Could also be a bad pickup in the tank, bad low pressure fuel pump, clogged fuel filter, or anything along the fuel line.
If it does not keep running when you squeeze the bulb, then you might have IAC or Throttle Body issues.
Of course, there are many other things that can cause the issue...this is probably as good a place to start as any.
Mike
