wynjim55
Following the general instructions on youtube I knocked together a home made carb synch gauge (manometer perhaps - two plastic bottles with two stroke oil to less than half full, connected by plastic tubing and fitted with two vacuum lines that connect to carb vacuum ports). Are these ok to use on outboards? I've seen them used to good effect on other multiple carb engines. Thankfully for me I only have two cylinders/carbs to balance.
I found that the oil doesn't flow easily between the bottles. Is oil too "thick"? Should I use other oil or water perhaps? I'm only using 3mm I.D. tubing as that is what fits the ports on my carbs, is this too small to allow good flow?
During this process I checked the linkages between the two carbs and found that both the butterfly's and choke plates were nowhere near synchronised. Fixing this alone will make a big difference no doubt.
