"1979 Evinrude 85hp 85999R
Took out the boat today as I was idleing away from the ramp the prop hit a rock. Motor quit. It will re-crank with the fast idle lever up. It now runs real rough. Has a huge miss in it. Will not run at all now at idle or in gear it just misses and cuts off.
Also yesterday it ran perfect at idle but had a miss at ful throttle. NOthing like now. It still ran good with the little miss then. Removed plugs and can easily turn flywheel. Pistons move up and down just fine when I do.
Has new coils, power packs, fuel pump, carbs rebuilt, wires and plugs."
