High Temperature Warning Horn/Buzzer
1984 Tidecraft
Hello all, I have a question about my high temperature warning horn/buzzer on my 1983 Johnson 115 HP V4 motor. Does anyone know for sure if the horn/buzzer is supposed to make a chirp/buzz sound when the key is first turn on, on a 1983 Johnson 115 HP V4? It seems like to me, years ago it used to when I first turned the key on, but I can't remember for sure. I did some research on the internet, and I am getting different information. Some of the information said it should chirp/buzz when the key is first turned on to let you know the warning horn/buzzer is working. Some information said it won't chirp/buzz when the key is first turned on, on a 1983 model and you should test it from time to time by grounding out the wire that goes from the horn/buzzer to the temperature sensor. The same article said the warning horn/buzzer will make a chirp/buzz sound on later year models when you turn the key on, but not on a 1983 model. Thanks
