I have a 1987 Mariner 60hp, 3 cylinder, 2 stroke outboard. It's mounted on a 1987 Bass Tracker boat, this is an all original set up. It was given to me by my grandfather, that's owned it since new and always had to professionally maintained. It has been sitting for the past 5 years in storage, it was professionally winterized before storage. Anyway, my issue is that I cannot get it to run over 3,000 RPM's. It starts right up and idles fine, it also runs good up until 3,000 RPM'S but then just sits there and won't go any higher. It doesn't cut out or anything. I can't even really get my boat to plain off with me and another person. All of the spark plugs look good and there all firing, they were replaced when I got the boat from my grandfather. I replaced the water pump impeller, cleaned the carbs (they were not clogged at all, all of the fuel was removed before storage), I replaced the fuel water separator filter and the fuel line from the tank to the outboard. I've tried two different fuel tanks and the engine ran the same so I know it's not the tank. I am going to rebuild the fuel pump either tonight or tomorrow and replace the fuel lines under the power head cover, but I don't think that they are the issue. I tried pumping the fuel line bulb while running and it still would not run over 3,000 RPM's. I checked the throttle linkage and it is going to WOT when pushing the throttle lever all of the way forward. I read that some of these outboards have a two stage stator but I believe the 1987's do not. So what should I be looking at next?
