I have a 06 Crownline 240EX with a 350 mag and bravo3 outdrive. I found gas squirting out from where the fuel line comes from the fuel module It is held in place with a set screw. It was real sloppy at that connection and I replaced the quad o-ring and the housing that the line goes into. tighter but still sprays fuel around the o ring and the stainless line. Could a bad pressure regulator be causing it to have too much pressure? I can't blow through the regulator but not sure if I should be able too.
Please advise !!!
Please advise !!!
