"After reading posts here for
"After reading posts here for quite a while this is my first post.
I have a 1991 Glastron with a 130 hp 4 cylinder Mercruiser. It's out of the water for the season now (it's already cold here in NH); but the following symptoms, at first very infrequently, gradually becoming more frequent, began during the season.
A high pitched squeel eminates from the engine compartment and at the same time the voltmeter is pinned past 16 volts. Backing off the throttle usually stops the squeel at which time the voltmeter pops right back to 14 volts. This initially happened at high rpms, but towards the end of the season it seemed more random, happening at lower rpms as well.
The belt seems to be tight enough - about a 1/2 inch of flex or less. Common consensus amongst fellow boaters is that the alternator is going bad but I figured I'd ask here for any input as well.
Another problem, which I think may be related, is that after running hard (high rpms) for some time, the engine will very infrequently stall at idle then not start again for about an hour or so.
Otherwise this has been an excellent, dependable boat and motor.
Anybody have any ideas as to what may be going on?
Thanks in advance for your help!
David"
David"
