High idle
NitroB
1991 115 hp Evinrude. Rebuilt carbs new fuel lines ran at lake once did fine noticed bottom carb fuel line was leaking some pulled carbs back off just changed lines to both carbs. Ran motor in driveway idles high at 2400 rpms. carbs in sync open and close all the way cannot find any air leak. Any ideas what it could cause this?
Is the cam touching the carb roller? Have you tried turning the idle down with the screw? Did.you link and sync the carbs?
