"I have a high idle on a gt150
"I have a high idle on a gt150, 1100 rpms idling, I had a problem with firing and have new stator,timer base and rectifier. I returned the base and rectifier tested bad and recieved new parts. The motor is 3 to 4 degress below set point AND still idling high. 1100rpms.I have a dva adapter and meter, what wire is tested for signal to start quickstart? I was told it was black/white stripe wire going to timer base. I am not sure and if is right wire what is the voltage reading and do you use the dva adapter or just measure it to ground? I have ground the white/black wire from pack to temp sensor and made no difference to rpms. Is correct idle 700 to 800rpm??? Any info would be great Thanks Mike."
