High Idle at start up.
jtw37
Just got my 1975 50 hp Johnson outboard started after new water pump impeller and carb cleaning. It ran rough, so I adjusted the air fuel mixture which smoothed it out, but the idle is about 1000 rpm's. (guessing) Where can I adjust the idle. I don't want to mess it up. Just need to get the idle down. Don't have a manual.
Thanks, JT
Thanks for the reply.
It is in my driveway with the tail sitting in a tub of water. I can put it in the lake, I just need to know where and how to adjust the idle
You need to get a tach and your idle might be ok where it is. If not there is a screw on the throttle linkage I believe it's a hex screw.
