David Foti
Hi Folks,
I have a 98 tracker (made by mercury) 50 hp yamaha power head
the motor had a really rough idle so I cleaned the carbs and solved that issue but the engine everytime after it warms up when I put the engine into neutral it will race up to over 2k and stay there.
So I've checked timing the head was removed at one time but it was installed correctly , checked compression 150 + all four , checked coil and trigger resisitance good , so I put a timing light on the engine actually and it is around zero at adle I then let it run in gear for a few minutes put it in nuetral teh timing was around zero for a second or two then went to 20 + degrees advanced like it was wot timing ??
the only thing I can figure at this time is a bad cdi but I'm asking for input ??
thanks in advance
oh btw the controls are not binding or hanging up
so its fine if I never have to put teh boat into neutral but thats wish ful thinkning while dockinig
and the idle is fine when I first start the boat if teh engine is cold
thanks in advance
