"from another site I posted th
"from another site I posted this
09:00:17 Quote From Merc Manual-Vent Jet
The vent jet supplies less than atmospheric pressure to the fuel bowl at mid-range, which results in improved fuel economy. If a jet with a smaller orifice is installed the mid-range fuel/air ratio will be leaner. If a jet with a larger orifice is installed (or jet is removed) the mid-range fuel/air ratio will be richer.
Rejetting Carb for High Altitude
If the engine is to be operated at an altitude higher than 2500 above sea level, it is necessary to rejet the carbs. BLA-BLA-BLA
2500-5000=main jet .002 smaller than standard
5000-7500=main jet .004 smaller
7500- and up=.006 smaller
Carb #
wmk 33-1 main=.072 vent=.096
wmk 37-1 =.072 =.092
wmk 38-1 =.072 =.092
All this info is for a merc 1983, 40hp, 2cyl, I don't have any other info but it should apply to your engine the same. Just find your specs and go from there."
