strangerover
Hi to you all. I bought my first powered boat a few weeks ago after years of kayaking, a small inland cabin cruiser with a BF15A on the back. the engine ran ok but very smoky. Seems the previous owner had been fiddling about with it with no mechanical knowledge whatsoever!
First I found the engine oil had been filled to halfway up the dipstick. It was clean-ish and I had no fresh oil to hand so I drained it off to the correct level. That cut the smoking down but on the next journey out the 15hp twin turned into a 7.5 single. The plugs came out black and oily/sooty. Maybe just the excess engine oil fouling the plugs I thought, and replaced the plugs. Ok for a few hours running then back onto one cylinder (always the lower one). I removed the carb for a check-up and found what I believe was the pilot mixture screw on the right hand side of the carb. This was around 5 turns out! I presume (years of biker experience talking here) this is usually between 1 and 2 turns out and I reset it at 1 1/2 turns. I had to reset the idle speed when refitting and I've yet to check the colour of the plugs now but it was faultless for the 5hr trip back. Well... almost. My oil pressure light goes out when the engine is idling, comes on fine as soon as revs rise. This does not happen when cold, just when the engine has reached full temp.
Ok so 2 questions.
1. Does anyone know the factory setting for the pilot screw?
2. Is the oil light normal? Have I just turned the idle down too low, I set it to 'as low as it's happy and not stalling when put into gear'. It does seem a high idle to get the oil light flickering and it's constantly lit when cruising. I will give it an oil change next time I go down, what grade should I use?
Ok so 2 questions.
