HelpTell tale hose elbow
rrandy
"While trying to clean the hos
"While trying to clean the hose for water passage on my 85 Johnson 8HP, I borke the telltale hose elbow.
Any idea on how to replace it?
Thanks"
"Randy--
the website at [url=
"Randy--
the website at www.evinrude.com has exploded views and parts lists for motor made after 1968. You should be able to find the part and its number there and then order it from any number of vendors."
"Some way or another, you'
"Some way or another, you'll need to remove the remainder of the telltale's nylon threaded portion from the exhaust housing.
After which, clean the threads with a pipe thread tap (tapered) of the proper size. Do not attempt to use a regular type tap as that will result in not being able to tighten the new telltale fitting."
