HELPPPPPPP
racer9115
93 TRACKER JOHNSON115
prime bulb takes quite a while to get hard. once hard motor will run for 2-3min and start to die (assuming shortage of fuel) becuae the prime bulb goes soft. any easy test to test for air in fuel system or leaks. make it simple because iam thinking too hard about it.
Test with another tank and hose.----Another clue might be evident if you post the ACTUAL compression test values.-----Running with VRO ( tested ) and in service or a different pump.?
