HELPNEED A STATORPOWERPACKSampCOILS
josh
" I NEED 1 STATOR, 2 POWERPACK
" I NEED 1 STATOR, 2 POWERPACKS & 3 COILS FOR A 1984 FORCE 85 H.P.USED WOULD BE FINE AS LONG AS THEY WORK THANKS JOSH. "
" Josh,
You would be better
" Josh,
You would be better off going to www.seilermarine.com and buying those parts right there. These would be rebuilt units from Rapair, and the price at Seiler is very reasonable. If you ordered the parts from Mercury you would get the exact same parts, but the cost would be far higher. Used parts are not advisable here. It is impossible to tell if used ignition parts like these are in good condition. You probably would not save much money anyway.
I noticed your post regarding the flywheel. I have had the same trouble with countless Force flywheels. I remember retapping the threads in the flywheel puller holes for larger and larger bolts once, and finally suspended the engine with two steel plates under the flywheel. Then I pounded the end of the crank until the thing separated. After recutting the threads on the crank everything worked out okay, but I have seen mechanics who were not so lucky and ended up destroying the flywheel before getting it off. This is why I always acquire Force flywheels if I get the opportunity. They come in handy every so often.
Tony "
