I have a 1987 Yamaha 25 electr
I have a 1987 Yamaha 25 electric / manual start.
I took the boat out for the first time this year and the impeller went out. Was running fine. I replaced the impeller. Carried the boat back out and it cranks and pee's. Well When I crank it and put it in gear it wont hardly go past idle fast. I can slip the cover off and manually speed the motor up to wide open throttle but when I put it in gear and throttle on it wonnt go much past idle. I pulled the GAS LINE off and it took off like normal. When I put the gas line back on an pump it up it does the same thing again. I can actuallt be running the motor on the water in gear and slip the gas line off. The motor speeds up and runs like a dream until all the gas runs out of the carb. Its like its gets too much gas when the line is on or something ????
I have checked the gas line and tried running the tank with the cap tight and the cap loose. CRAZY MAN. WHats wrong with it ????
TB
TB
