evinrudekid
Hi, I have a 1986 60 hp 2 stroke mercury outboard serial number: 0B201098 . As of 2 weeks ago the tilt/trim on the motor worked fine, but wouldn't fire so I bought new and replaced the rectifier and stator. I then tried the motor and it fires and runs great. However when I tried the tilt/trim it goes down fine but when it push the button for it to trim up I only get a clicking noise. I tried messing around with the solenoid connections a little bit but that didn't help at all. I was wondering what could be wrong/how I can troubleshoot this problem???? Also wondering if there's a release on the motor to disengage the trim so I can manually raise the motor and where that might be??? I appreciate any advice on the subject.
