Hello: My 1987 Yamaha 25SH has no spark. I am trying to remove the flywheel (which Yamaha calls the rotor) to help diagnose why there is no spark. Do I need to remove anything other than the 24mm top nut to pull off the flywheel? I am using a 3 arm gear puller and I have put a lot of torque on the gear puller without budging the flywheel. Are there any other bolts or anything else that need to be removed to free the flywheel? Please see the pictures, attached. Thank you in advance.
