I was given a Mariner 9.9m, serial number 682cl-321484. I'm attempting to locate a Rectifier for it, but I'm having doubts about which one is the correct one for this motor. I have been told that it is no longer available.
Also, in the parts listings, I have found that within the serial number range I have searched, I am unable to find models that use points. I have seen numerous models that have a CDI ignition..
Am I trying to repair a motor that can't be repaired? I have spark on one cylinder, but not the other. When i reverse the wires, i have spark on the other side, but not the first.
The winding is damaged on the rectifier that is currently on thi motor.
If anyone can help or point me in the right direction, I'd sure appreciate it.. Thanks in advance..
