sterracina
My 1999 SeaRay 180 BowRider has 2 drain plugs (one blue plastic and one brass) that I remove every fall to drain all the water from the engine. Well I lost the brass plug. The engine is a Mercruiser 3.0. I've gone through online parts catalogs and ended up with Quicksilver 22-328022. However I can't get the threads to catch when attempting to screw it in. This screw is on the bottom so you can't really see it when trying to screw it in. The serial number on the engine block is L328943. You can't read any of the serial numbers on the air intake. Is 22-328022 really the correct part? Any idea why I can't get it to catch? It feels like the tip goes in the hole, but it just won't catch when I turn it. The bolts have a red solution on the threads. Is it possible that this is what is preventing the bolt from catching?
When I removed the brass plug in the fall, I decided to replace it because the head of the bolt was worn. I had it in my truck, but the truck was totaled in a rear end accident and I couldn't find the bolt after the accident. I've attached a few pictures.
Thanks,
Sam
Thanks,
Sam
