"I'm not sure of the year
"I'm not sure of the year but the serial # is OD293818. The problem. The motor starts fine with the prime switch pulled out but after pushing back in it chokes out. I noticed that even after running for a while the water from the outlet is lukewarm at best. At one point I heard a click, and the motor ran fine with the primer pushed in, but after turning it off and restarting it, the problem continued. My question is this. If the thermostat is failing and the motor is not reaching operating temperature, could that cause the choke to fail to open? Thanks for any suggestions. Ed K."
