A
Attila Jeney
Guest
" I just got a used boat this
" I just got a used boat this summer(first one, 94 crestliner v170 sportfish, 93 johnson 90hp).
I have had a couple of problems with the motor.
Sometimes it takes a little long to warm up at the launch. I take it out of idle into gear and it quits. have to start/restart a few times.
The first month I had it, while out on the lake the motor suddenly powered down on me. No warning at all. fished for a while. Got it started, rought idle for a few minutes and then okay. 3 weeks ago from this week, was out again, coming back from a spot in the lake the motor just powered down. No warning. Could not get it going. Drifted and fished for a while. Changed out the plugs and spent 10 mins trying to start it. Got it going. Went about 2 miles and then it quit again. Cranked for a bit but only got it running in idle.
Took the rig to 2 shops for compression test. Top 2 cylinders were 110 psi, bottom 2 read 80 and 85 psi each. Both said to rebuild the engine. One quote was 2500 (rebuild powerhead, carbs, new vro pump, checks water pump, puts about 9 hrs on it in his tank, 1 year warranty). forget the other shop. Have one more to take to.
Granted I am new at this, based on the compression is this really needed?
Also, The same shop said he was getting a 98 115 hp johnson oceanrunner in on an upgrade. Used 120 hrs in fresh water. Rough price about 3200 but will give me 600 trade on my motor and I will have to change out the wire harness( another 300 or so) Is the oceanrunner a good engine?
Depend on the price should I just upgrade or get the current rebuilt. My boat is rated to 140hp.
thanks. "
thanks. "
