My 2000 mag mpi 454 stalls only when its cold out at the first start. It also gives a series of beeps. It was checked with a scan tool and the only code wss a #14 coolant temp sensor. The iac and this were both changed and still same results. It is only at the initial start and after that its not an issue. We did what mercruiser reccomends to test the sensor with a voltmeter and it showed over 5 volts. Any help would be great.
