Greetings all,
Hoping someone can help ID a 35 hp Force I bought recently. The ID sticker is missing. From searching through older threads, I've seen this is a common occurrence. The motor runs great on muffs, but I think I need to at least change the impeller before I put it in the water. I need to get a repair manual, but looks like I need a model number and year of mfg to get the right one.
1) The lower cowl is aluminium and has "MADE IN USA" followed by a circle with the numbe 90 in the center.
2) The carb is made in Ireland by Tillotson. There are some identifying letters and numbers on the carb's mounting base. 717061-1 is stamped on one ear. On the other ear is stamped WB-106B-036
3) The transom bracket has some ID markings. The top number is 2014, ALCOA directly below, 684532 is the third line, with 83-2 on the bottom
4) On the starboard side of the engine, in front of the fuel pump & filter, the number RW504222 followed by a circle with the number 90 in the center.
5) The flywheel is marked PRESTOLITE ELECTRICAL DIVISION
6) The control panel is marked US MARINE
Thanks for any assistance
