Help with 19 85 johnson outboard motor
E
eunice cook
Guest
" yes this is my first motor a
" yes this is my first motor and i don,t know what the oil and gas mixtue should be. i am a grandmother and im trying this out. its a 15 horse 1985 johnson outboard motor. what kind of oil and how much it says something about 2 cycle. appreacate all the help i can get, i want to go fishing. thanks Eunice
please email me and let me know soon "
" Eunice.... That engine uses
" Eunice.... That engine uses a 50/1 fuel/oil mixture (1pt of 50/1 oil to 6gal gas). A gasoline octane rating of 87 will be fine.
The engine is a two (2) cycle engine, meaning that the piston fires every time it revolves.
Visit your local dealership, either Evinrude, Johnson, or Mercury and pick up a few pints of two cycle TCW-III 50/1 oil. The "TCW" stands for Two Cycle, Water Cooled.
I assume you'll be using a six gallon portable tank. It's best to put one gallon in, then the pint of oil, then the rest of the gas. If you put the oil in a empty tank, the raw oil will be forced up into the pickup tube inside the tank which will result in having that raw oil fed directly to the carburetor instead of a mixture.
Joe (30+ Years With OMC) "
" thank you very much. i will
" thank you very much. i will do as you say. i am going fishing tuesday, wish me luck "
