Help ...... where do I start?
bmdakk
86 e50belcde...on a 25' crest pontoon.... Ok I replaced the thermostat and impeller yesteday. Had a good stream coming from the pee hole before I did the job. after , not so much.. While sitting in the yard with the motor in a tub of water. it started fine and had good throttle from Idle to WOT.
I took it out on the river this morning. took forever to get it running and warmed up. The stream coming out of the pee hole was just a trickle, (had a harder stream in a tub of water). Finally got it warmed up to where it would go into gear with out stalling, and it wouldnt go faster than 4-5 MPH( just a guess as it doesnt have any guages).
We went about 1000 yards up the river and I noticed that the pee stream kept dwindling to almost nothing so I turned around and headed back to the ramp. while doing this, when I steered either left or right the motor would race and sounded like it was slipping. Im at a loss as to where to start. any suggestions on what to look for?
here is the problems for now
1. wont idle in the river, but will in a tub.
2. pee hole is almost non existant in river but decent in a tub or with ears muffs.
3. No speed at all with wot , Id say it isnt even 2000-2500 rpm . I have tried while hooked up to muffs and it engages into gear and prop turns and revs high, but not in the river.
4. While turning in the water motor seems to be slipping( almost like pulling a clutch lever on a motorcycle).
Where do I start????????
Start with a compression test.--Then check to make sure there is strong spark on both cylinders.-Spark should jump a gap of 3/8" or more.
Did a compression test before I replaced the stat and impeller. 128 on the top and 125 on the bottom. Didnt check spark. will try that after I get the carbs cleaned and back on. Thanks.
