Ok folks I just got it out of the shop with a tune up and clean carb. Put the boat it today and this is what happened:
1976 Crestliner with OMC 165hp inboard
Started no problem, got gas at marina and headed out on the lake. Was cruising at about 2500 rpms with no problem then I increased the throttle and just started to to move a bit fast and all of the sudden it felt like I was tied to a dock and a rope was pulling my boat to a stop. I to off the throttle and let it idle a bit then I hit the throttle again and it was moving for about 1 min and then bam! The same thing it just pulled right back. This happened a few time to the point where I had to head back to the marina going very very slow. I could no longer even get it going medium speed without the boat pulling and chugging along.
Is it the fuel pump, or is there a leak. What do you guys think?
Under the steering wheel there is a tube going from the gas tank and around to the engine in the back. In the middle of the tube is a plastic or glass tube inwhich you can see the fuel in it. When the boat is off the tube has 1/2 fuel and 1/2 air. When I start the boat it is solid fuel. When I am driving the boat and experiencing a pulling feeling I look under an dit looks like air bubbles going through that glass tube. Is that normal?
