Travis Wallace
Just replaced the impeller in my 1960 Johnson 40. This motor has a two-piece shift rod. Access panel on side of midsection allowed me to remove the connector's bottom screw and pull off the lower unit. Any tricks on how to get the end of this rod back into the connector's hole? I know it's important to align the notch with the set screw, but I can't get the rod into the hole at all, never mind "lining it up." Any help would be most appreciated; thank you!
