Help Removing Oil Injection System From Mecury 150
acleme1
"I am removing the oil injecti
"I am removing the oil injection system from my Mercury Outboard, and need some guidance. Any help would be greatly appreciated. Here we go...
The air line that runs to the remote tank is bolted into the block at the bottom of the starboard side. How do I plug this off once I remove the air line?
Once correctly rerouted, the fuel line will run straight from the fuel connector to the bottom of the fuel pump. Does that sound correct?
BTW - I own a 1988 Mercury 150 XR4 Black Max. Thanks again for the help. AC."
