floridakj
I have a 97 sportcraft 252 that I need to pull engine out, problem is corrosion on flywheel housing bolts, and clearence around bellow tube. when the motor mounts are pulled will engine slide forward with out removing the housing bolts? engines I have removed in the past were also mounted on gimble housing, I can not understand how this will come out if these bolts have to be removed, I have pulled the cylinder head and need help with the rest,Thanks
