mcw
Hi all
Could any help my reconise this throttle lever/assembly, ive been having issue for a while now, when engaging forward throttle the gear cable automatically engages in to forward gear, but what been happing is it gets stuck in forward gear when i come back to neutral, and it also getting stiff to move, have checked all cable and linkages on the v/p 290 sp leg all is ok and very smooth.
Ive taken the throttle apart now several times, clean and re-greased it up, there is inside 3 bearings and springs, 3 colors and several alu moldings
Could any one help me find out if its a serviceable item, is there any info on correct set up, or any other info that will tell me the manufacturer. the throttle its fitted to is a 1994 wellcrafty 20 excell sports cuddy, with a v/p 4.3gl/430b petrol engine
I don't know how easy it would be to replace it for another newer throttle.
Any ideas gracefully received.
mark
mark
