C
claudiusdrusus
Guest
" Dear all,
I need some h
" Dear all,
I need some help and advice. About 3 weeks ago my 1990 Mariner 200 HP developed a crack in the powerhead (I think this is right - the metal casing that the houses the cylinders and pistons) such that it couldn't be sleeved and had to be rebuilt - or so I was told. I had the entire thing replaced replete with new carburators (3), gaskets, 2 new pistons etc. The powerhead itself came from a used engine. The mechanic found the part and rebuilt the engine. We tested it together running the engine for an hour. It was fine. Yesterday, I took it out for the first time and ran it. About 1 hour in, it suddenly began to make a loud cranking noise and about 3 seconds later simply died. When I opened it up, I was shocked to see the entire powerhead my the top left cylinder had burst apart, the rods had been thrown along with about half of the engine. The mechanic has basically said to me "that is the way the cookie crumbles. Probably some contamination in the gas tank that lead to over compression in the cylinder causing it to explode." Is this a viable reason? What should I do. PLease help!!! Is my engine dead? "
I need some h
" Dear all,
