R
rustychicken
Guest
Here s my problem. Replaced wa
Here s my problem. Replaced water pump with full pemp kit. Also replaced prop shaft seals. Started engine and let it run for 20 minutes or so. Pumping water perfect but here s the problem. There was lots of oil in the water when i shut it off.Oil was dripping out from behind prop shaft. Took lower unit off and found the grey oily goop all around where the water exits the pump to go up into the motor. Would this possibly be the seals under the waterpump are shot? Any help would be greatly appreciated.Thank you in advance for any help......Gettin frustrated in ontario....this forum is great!!!!!!
